9 in wheel bearing spacer?
Old Feb 7, 2008 | 05:46 PM
polky's Avatar
polky
do you really need it? just bought the set and the spacer doesn't fit. bearings fit just fine. what does this spacer do?
Old Feb 8, 2008 | 11:39 AM
rebocardo's Avatar
rebocardo
It retains the bearing. In the FWIW category, double check the part numbers. The 1979 with the seal on the shaft is a different kit then the seal in the axle housing.
