Truck stumbles, dies, wont restart
Anyway, it will start up fine and after i put it in drive and hitthe gas it falls on its face and dies, then wont restart. When it happened yesterday I could not get it started for about 15 minutes and then i held the gas pedal to the floor and it fired up. What would cause this? Im pretty sure its a fuel problem but im not sure what problem . .
Any help would be much appreciated.
Thanks, Dan
Oh . . Its a 1990 F150 302L Auto
If you look toward the back of the fuel rail on the drivers side, you'll see the FPR. It will have a vacuum line going to the intake plenum. Pull that vacuum line, and see if it smells like or has liquid fuel in it. Another test to confirm, but make sure you don't try to start the engine when you run the test, is to cycle the keyswitch on a few times with that line off. If the FPR is leaking, fuel will come out the nipple. It's simple to replace, albeit, you have to do part of it with feelavision. If I remember right, the hex-key bolts are metric, so hope you have some metric allen wrenches in your tool arsenal.
If it were a fouled injector, that's another possibility, but fouled injectors are fairlly uncommon. There is really only one way to get too much fuel in that engine for it to start. Even if the ECM were in fail-safe mode, it should start relatively easy. Mind you, it would have virtually no power and will probably smoke like a coal fired locomotive. But, if the FPR is toast, that too will make it smoke very black.
I have not worried about it too much lately because it has not happened for two weeks. I will look into the FPR and see if it is leaking, although the truck does not puff out black smoke.
