need advise
Go here to see how to check codes without a scanner
http://www.fordfuelinjection.com/?p=13
or you can buy an OBD1 scanner at Advance for $30.
You're problem could be fuel related........Does it idle ok? There is a fuel pressure regulator FPR that could be a problem. It is possible it's a filter clogged.
I had a truck once that had a bad coil wire and when I thought it wasn't taking fuel it wasn't.......because the coil grounded out and shut it down.......then it would unground and take off.
Try getting the codes and let us know......you'll get lots of help here.
Good Luck
Bob
