Sponsored by: Real Truck
Plugging my truck in for the winter
Old Oct 29, 2007 | 12:54 PM
harstad23's Avatar
harstad23
First winter since I bought my '05. I'm in Omaha, Nebraska and it gets pretty cold here sometimes. I work from home and I dont want to plug my truck in all the time , because most days, I dont go anywhere. So what are my options? Ive thought about plugging it on one of those timer switches. If I do that, how long will she take to be ready to go?
I've also heard about fuel gelling. What do I need to do about this? What temps should I even worry about this stuff?
thanks.
Old Oct 29, 2007 | 01:06 PM
navistar2000's Avatar
navistar2000
Welcome.
Most of the people around here that use their heaters on a timer seem to set them to start between 2 and 3 hours before the truck is needed. In so far as anti-gel, most stations, I assume nationwide (maybe bad assumption), but at least in my area add anti-gel into the fuel loads. If we get a real cold snap here, I have put some extra in for precautionary measures but only for an extended cold snap under 10 deg F.
I'm sure others are going to add their insight as well.
CM
Old Oct 29, 2007 | 01:12 PM
the Goat's Avatar
the Goat
The 2008 manual says there is no point in running the heater for over three hours because it reaches the maximum tempature after three hours.
Old Oct 29, 2007 | 01:29 PM
DonJames's Avatar
DonJames
U will probably need to get one of those extra heavy duty timers (like a window A/C timer) since the block heater draws about 15 amps.
Old Oct 29, 2007 | 02:01 PM
UP_There's Avatar
UP_There
I used to use a timer, and always had it set for 2 hrs before I left for work. I work on call now though, and this doesn't work out. I've never had a gelling problem, even when temps are 0 degrees.
Old Oct 29, 2007 | 02:03 PM
Beerstalker's Avatar
Beerstalker
These guys have you covered on the block heater question.
As far as fuel goes it is always a good idea to use an additive since it is cheap insurance. The most commonly used, and readily available one is probably Power Service. The white bottle is the one for winter use with Anti-Gel properties.
http://www.powerservice.com/dfs/
Old Oct 29, 2007 | 02:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Since it's almost winter time.. can a Mod write up a FAQ on block heaters and add it to the tech folder or make it a sticky? There's already been a bunch of these this year.
Old Oct 29, 2007 | 07:16 PM
barnbridge's Avatar
barnbridge
The block heater draws about 1100 watts. I've tested mine. I also use a Wolverine oilpan heater, 250 watts which total 1350 watts which still work fine with a standard timer from Walmart or the hardware store.
Old Oct 29, 2007 | 08:04 PM
belandd's Avatar
belandd
Winter Plug In
I use a oil pan and a trans pan heater as well as the factory block heater on my 06 SD.
They make special heavy duty timers that will handle this load.
Old Oct 29, 2007 | 09:53 PM
rjmay's Avatar
rjmay
I wired a trickle battery charger with the block heater and have both set for 2 hours before drive off time. Just getting the batteries charged slightly improves CCA.
Old Oct 30, 2007 | 07:40 AM
Tungsten's Avatar
Tungsten
Yesterday I bought a heavy duty "appliance" timer (rated at 15 amps) at Lowes yesterday and tested it out with my F250 this morning. It worked like a charm. I set it to turn on at 4:30am and cut off at 6:30am ... right about the time I'd be wanting to leave for work.
When I went outside around 6:15 to crank the truck and let it warm up, the ambient temperature was around 37*F. The indicator for the glow plugs just flashed on briefly like it would have were the truck warm from running, and she fired right up.
Old Oct 30, 2007 | 08:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Does anyone use a battery heater?
Old Oct 30, 2007 | 07:33 PM
BareBones's Avatar
BareBones
I'm in Minnesota but I've never used a battery heater, though my son "almost" has. I.e., Last year portable booster batteries were all the rage so he got one to go with his 18-yr-old Buick and 10? year old battery. It not only provides extra juice when things are really cold, but the booster is as warm as his house!
Old Oct 30, 2007 | 07:47 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Years ago, before fuel injection, ecm's and the like, I just put a 100 watt heat lamp on the intake manifold, closed the hood and threw a mover's blanket over it. At 20 below it made a big difference. Course back then intake manifolds were cast iron ...........and gas was 29 cents a gallon........
