Modular V10 (6.8l)
v10 ignition coil replacement
Old Oct 4, 2007 | 11:44 AM
MABGADGETMAN's Avatar
MABGADGETMAN
Question v10 ignition coil replacement
Does anyone know if there any illustrations online of how to replace iginition coils on the V10 and how to test which onwes are bad? the dealer charged $280 to replace 1.
FYI just had a new engine put in my 2001 oil pump went out at 107K i couldn't believe it.
Old Oct 4, 2007 | 12:38 PM
Big Orn's Avatar
Big Orn
Welcome to FTE, MABGADGETMAN!
To replace the coils, all you have to do is disconnect the power source, which is just a plug/receptacle, then remove a small screw. You just pull it up then.
As far as testing which ones are bad, it depends on how bad they are - that is - if they have failed completely or if they misfire intermittently. Hard to find them when they only miss under load, or right at start-up, or just a few times during the day.
The dealers have a diagnostic procedure whereby they locate failures through a piece of equipment called a WDS (Worldwide Diagnostic System). Pretty good at it, too, and charge anywhere from $50.00 to $125.00 depending on location and your PR with them.
$280.00 just for coil replacement is pretty steep. I think you can buy a coil now for $40.00.
Oil pump, huh? Sorry to hear about your troubles. Did you buy the truck new? Do all your oil changes and such?
Old Oct 4, 2007 | 01:50 PM
dkf's Avatar
dkf
$280 to change a COP.
Thats why they call it the Stealership.
Big Orns got you covered.
Old Oct 4, 2007 | 06:19 PM
dajkzo's Avatar
dajkzo
It was time to replace the COPs recently, I went with the Accel packs from Summit Racing, they came with the wire and boot at $27 each. I was seeing the classic shudder in overdrive at 1700 rpm, no codes, and the packs ohmed out. (I hate static tests on coils)
Easy part to replace, except the last 2 on the passenger side, but even those were not enough to make me say &^$(#j(@
So far about 1500 miles and I'm happy with the performance.
websurfer
19
Feb 21, 2024 06:19 PM
Rosson03
Feb 26, 2011 03:32 PM
jeff2011
Sep 7, 2009 10:54 PM
PowerStrokeHD
Mar 10, 2008 08:34 PM
Greem
Oct 1, 2007 03:57 PM
