1994 f-350 4x4 auto trans shifter sloppy
I have a follow up question - even though my inital question wasnt addressed as yet ------would a junkyard column from a E4OD or AOD truck work with the c-6 ...I believe they all have the same detents for P-R-D-2-1 the OD trucks just have the button on the end of the shifter that I could simply not use - it all else works
How about it ? ....sombody out there must have tried this because most well used trucks have this issue.....thanks in advance
hey buffalobob i have great news for you. you don't have to go to the junkyard and pick one up because your shifter isnt broken its just loose. I had the same problem and all it is is that theres a nut in the steering column under the dash that needs to be tightened. All i did was open up the dash and tighten that nut and the shifter was as tight as ever. hope this helps.
