I think you have other problems if you're blowing plugs...
Actually no, these modular motors 97-03 are prone to blowing plugs out of the head due to a lack of threads in the head.
davisenvy,
I would check the plugs twice a year or so just to make sure that one or two haven't loosened themselves. Other than that, it's basically cross your fingers that one doesn't fly...
I'm new to this board but after reading all the posts discussing this subject i'm of the opinion that the plugs that blow out were improperly installed and were over tightened and stripped when they were replaced. These plugs are left in place and gradually over time work themselves loose and eventually blow out. I hope that none of the plugs that were originally installed at the ford factory have blown out. There are 100s of 1000s of these motors in use today and I think it would be a much bigger problem if it were a factory defect.....I don't know...just my 2 cents....sd
Actually it is a huge problem if you are one of the the many people who have had one or more blow. It's fairly obvious to most observers that there was a problem with not enough threads in the heads for several years. Carefully torquing the plugs to spec seems to reduce the problem, but there are far far too many posts from people who just got unlucky even when their plugs seemed appropriately well torqued. It does seem to happen more often with the 5.4L than with the 4.6L though.
I'd just suggest that you might want to hang on to that 2 cents until you research this problem a little more. There are a lot of us who know darn well that our plugs were torqued correctly. There are hundreds of posts at a minimum on this problem....and lots on the F-150 forum too....
And to rattosh51, since you have been around the forum for a while, I have to respectfully disagree with you. I'm sure you already know that there are a lot of other owners who will also disagree. They and I believe that the threads were a distinct problem for several years (thankfully not any more). One of the reasons people were really upset was that Ford took so long to fix the problem.
But, at least the timesert and keenserts people have done a fabulous business with the repair kits.
This is why this is a great forum....learning every day! I had not heard of the blowing spark plug problem before, or I had just not read about it here. I've only changed my plugs once since I've owned my Expy, and I had a shop do it. Great, another thing to worry about. Glad there is a fix-it kit out there. Lack of threads makes this obvious as
to what is going on. Thanks for the education....again.
For those of you that have changed the plugs your self was there much if any antiseez on the threads. If there wasn't this could be part of the problem. The antiseez helps to keep the aluminum head from reacting with the steel plug. If there isn't much on there galvanic action could be corroding the threads and since there isn't much in the way of threads to begin with, they blow out.
Matt
Isn't this process also called electrolysis? This happened to the slide out on my camper. You can't mix aluminum and steel. If this is the case, couldn't this be considered a manufacturers design defect. Ford should know better than that.
Like I have posted before, all of the modular motors since 1992 have had the same design and haven't had a problem with popping plugs. The problem with the trucks lies in the tuning. The trucks try to stay in closed loop for too long when going WOT which causes the truck to be too lean and the cylinder pressures shoot up causing the plug to blow out. If you look at the spark plug that blows out, you will see that the gap is closed. This explains it.
Drew of Stow OH (08/30/07)
I own a 2001 Mustang GT Bullitt and while driving a low speed I had a spark plug blow out of my passenger cylinder head. After doing some research this seems to be a common problem in any of the Ford 4.6/5.4/6.8 Modular Engines.
The spark plug was destroyed along with the coil that sits above it. The threads were also stripped out of the cylinder head as a result of the spark plug being blown out of the head. The only options for a proper fix require removing the cylinder head.
Above from Consumer Affairs.com. The cars blow plugs too.
Below is a link with many owners who have blown plugs. Be sure to have plenty of time on your hands when you start reading.
Steel plugs in a aluminum head is not bad as my vette is an 86 and it has aluminum heads, but I made sure to use antiseez on them and the ones that came out had it on them also, but most likly were not original. Just wondering if the factory plugs had it on them. I have 60,000 miles on my 99 and wonder if it is some thing to worry about.
So your stating here that the plug will only blow out if the go pedal is put thru the floor boards?
Your logic may be correct, but if the head had suffecient threads, the plug would stay put under these cylinder pressures.
