Modular V10 (6.8l)
Head oil pressure
Old Aug 22, 2007 | 07:23 PM
Mr. Obvious's Avatar
Mr. Obvious
Head oil pressure
I have a digital oil pressure gauge with the transducer mounted in the rear of the drivers side head up against the firewall. I am using Mobil 1 5W30 oil.
On startup it usually runs between 40-70 psi but under normal conditions, when warmed up, at a stop sign it will usually drop to between 20-25 psi. On a few occasions while towing and idling it would drop to 19 or 18 psi. However it generally drops to the lower 20's.
These are readings I have always been getting since I installed the gauges 4 years ago.
Is this an acceptable pressure at this location?
Old Aug 23, 2007 | 01:27 AM
skipperw's Avatar
skipperw
I also have a digital gauge. Use Mobil 1 5-30. Startup it shows 71. After it warms up it shows 61 at 70mph. Idling at light it shows 24.
Old Aug 23, 2007 | 08:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
As hot as my V10 has gotten, it's gotten at low at 24PSI - that's from the port where the stock oil gauge sender is in.
kevbits
41
Mar 21, 2016 07:02 PM
mike L
15
Nov 3, 2007 05:35 PM
Dingo1984
Dec 8, 2005 02:49 PM
greggmoore
Modular V8 (4.6L, 5.4L)
Mar 22, 2004 02:32 PM
butchs38
21
Aug 25, 2003 03:19 PM
