Replacing spark plugs
Old Aug 22, 2007 | 06:03 PM
57 t-bird's Avatar
57 t-bird
What is the best way to access spark plugs and replace them (pass side) in a 98 explorer 4.0 sohc engine? Thanks.
Old Aug 22, 2007 | 10:39 PM
mrshorty's Avatar
mrshorty
On my '92 OHV, I access #3 (and sometimes #2) by going from the side through the wheel well. I think the SOHC can be done the same way.
Old Aug 23, 2007 | 05:21 AM
marragtop's Avatar
marragtop
Yep, thru the wheel well. Also, remember to put anti-seize on the new plugs. You should also consider doing the wires since they are such a pita to get to.
Old Aug 23, 2007 | 10:47 AM
Bear River's Avatar
Bear River
Former ******
Make sure you replace them with OEM grand plugs and wires, Autolite or Motorcraft only. Otherwise you may find yourself doing the job again and/or having low power, pinging and detonation, and other problems.
Old Aug 23, 2007 | 12:57 PM
quicklook2's Avatar
quicklook2
and dielectric grease on both wire ends.
use motorcraft plat. plugs and wires.
Old Aug 24, 2007 | 06:27 PM
coyote0003's Avatar
coyote0003
Is this engine known for breaking the plugs off in the head when removing them ?
Old Aug 24, 2007 | 07:07 PM
marragtop's Avatar
marragtop
Not if you take your time and get a straight shot on them. Hopefully, whoever did them the last time used anti-seize. Some people make the mistake of putting WD40 on new plug threads. Not a good thing to do. When the engine heats up, it bakes the Wd40 into the threads thus creating a bond between the plug and the head.
Old Aug 26, 2007 | 03:57 PM
caseys's Avatar
caseys
I find it easier to replace the plugs by removing the front wheels and going thru the wheel well. Also, there are some mud guard flaps that will have to be popped off.
