39 ignition
Reason I ask is that I done the exact reverse on my 39 Car, and had to change the timming gears as the 8BA engine will force the cam to the front of the engine.
Where as the one you have in your 39, the timming gear will force the cam to the rear.
The gears have a different pitch on them.
Reason I did mine like I did was to have it look like the stock engine, useing 59A heads, and 59A Cam, with the Crab Cap Dist.
It was a 51 8BA Truck Engine, with A 4 inch Merc Crank and double carb intake.
Is your timming cover a 2 or 3 hole one? Either way you could use the 2 hole one and install the Crab Cap Dist, and go with either the Petronix, or Electronic Dist. If you need the spacer plate Dick Spadaro in NY has the adapter plate.
