Axle heat.
Old Jul 26, 2007 | 01:21 PM
Xyzzy's Avatar
Xyzzy
Axle heat.
I'm crossposting this from the exhaust forum because this deals with both. I hope doing this doesn't offend the FTE Gods.
I just had my exhaust dumped right before the rear axle. I drove it home and checked it and the area behind the muffler was pretty hot. (Duh!)
My question is if this will affect the axle or the clutch packs for my LS diff.
The muffler guy told me to expect the paint on the axle area to not stay on there long.
I have measured my diff case temp (outside) before with a cheapo IR temp gun and it was 120-130F normally, which is pretty hot.
The e-brake cable housing goes through this area too, but it was not hot to the touch. Only the axle, which was hot all over, but specifically very hot right behind the muffler.
So, am I going to cause any problems?
Old Jul 26, 2007 | 06:28 PM
andym's Avatar
andym
I wouldn't worry about the axle at all.
I'd worry about the gas tank right behind it. My truck was set up this way once - it didn't work very well at all when the gas tank got hot.
