Intake Manifold
Originally Posted by kermmydog
Edelbrock makes 2 different intake manifolds. One is NON-SMOG for pre-smog years, off-road & racing ONLY, & One is for SMOG ENGINES. So if you have smog you will need a SMOG MANIFOLD to pass smog.
You can't touch anything on your engine in California if you want to pass smog. I dropped my original carb and broke the case. I put an Edelbock on it and it passed the emissions test 30 percent cleaner than the old ford carb did, but the wouldn't pass it because it was modified. I JB welded the old carb back together, put it on and even though it was dirtier than the Edelbrock they passed it. I put the Edelbrock back on as soon as I got home.
If you don't want all of that plumbing on it document how it is ran, (So you don't forget) and then take it all off. When it comes around to smog check time put it all back on, go get it tested and then take it back off. But be warned that if you get stuck by an inspection and they spot it you could be in for some hefty fines.
