won't idle,.... was running great
Old Jul 7, 2007 | 10:03 AM
werpknarly's Avatar
werpknarly
Unhappy won't idle,.... was running great
1946 2ton heavy duty....
bought it 2 months ago out of north dakota. rebuilt carb, new gas, electric fuel pump, new plugs, installed pressure regulator set at 2.5 psi....
ran GREAT!!!! for 1 1/2 hour parade,,, 1st gear, low range, idle was PERFECT pace!!!! sweet....
on the way home she started giving me problems....
now it will only run at half to full throttle...
-starts easy with 6v battery
-seems to run rough
-sometimes loses vacum for 2-speed, but runs same way in low range
-exhaust manifold temp same across header on both sides ~260F
- water return pipes both show about the same temp ~160F
thanks in advance!
werp
Old Jul 7, 2007 | 10:14 AM
seetwisted's Avatar
seetwisted
Pull out idle/mixture adjuster,blow out with air? Have had to do this on my Carter a couple times...
rknight29
Apr 11, 2017 05:45 PM
Magnum199944
Mar 9, 2014 07:02 PM
ro11ovr
Modular V10 (6.8l)
Jun 13, 2011 05:08 PM
oldblu65
May 27, 2010 07:21 PM
