Axle U-bolt Torque ???
Old Jun 20, 2007 | 07:12 PM
brad3384's Avatar
brad3384
Hello I just added a 1/2 inch spacer on my truck(rear axle). And I was wanting to know what is the torque specs for the u-bolt nuts?
Right now they are 80ft pounds but I cannot find what the factory torque
specs nowhere. Thanks for the help. By the way 2006 4X4 screw.
Old Jun 20, 2007 | 07:32 PM
ohboy44's Avatar
ohboy44
This is from the service manual for light duty trucks. Heavy duty (7700) are much higher.
Remove the 4 U-bolt nuts, the U-bolt plate and the 2 U-bolts. Discard the nuts and the U-bolts.
To install, tighten the U-bolt nuts in 4 stages.
Stage 1: Tighten in a cross pattern to 35 Nm (26 lb-ft).
Stage 2: Tighten in a cross pattern to 70 Nm (52 lb-ft).
Stage 3: Tighten in a cross pattern to 100 Nm (74 lb-ft).
Stage 4: Tighten in a cross pattern to 133 Nm (98 lb-ft).
2civicrr
6.7L Power Stroke Diesel
Sep 4, 2015 09:47 AM
rfw0002
1997 - 2003 F150
Mar 9, 2011 10:44 PM
spdmpo
Mar 31, 2010 11:42 AM
Neal 97 250
Dec 5, 2009 11:50 PM
TallPaul
Jul 29, 2001 05:34 PM
