Intake cooling or heating?
Old May 28, 2007 | 07:05 PM
cadriver's Avatar
cadriver
Question Intake cooling or heating?
What's the job of the two hoses that run from the heater hoses T shape onto the intake manifold ?
If remove or bypass can this affect emissions "smog check" for those who are required by the State to do every two years?
I was just thinking to remove the two hoses cuz my area gets pretty warm above 100 sometimes, and the coolant might get the engine hotter.
Am I wrong?
Old May 28, 2007 | 07:26 PM
rubydist's Avatar
rubydist
They run heated water along the pcv system. In cold weather, the pcv system (especialy the pcv valve) can freeze and that is a way bad thing. All those hoses affect is the small amount of air that is allowed through the pcv valve, so I don't recommend messing with them. The engine is warmer than the coolant in the hoses, since the coolant is carrying away engine heat, so you won't do the engine any good or harm by removing them in your warm climate.
Old May 28, 2007 | 07:43 PM
RangerPilot's Avatar
RangerPilot
It's not going to get it any hotter, if anything it'll help cool it down. They're there to help prevent icing in cold weather as well.
Old May 28, 2007 | 10:56 PM
jimdandy's Avatar
jimdandy
Huh????? jd
Am I wrong?
Which hoses are you referring to? The intake manifold, or the throttle body? jd
Old May 29, 2007 | 12:27 AM
cadriver's Avatar
cadriver
Originally Posted by jimdandy
Huh????? jd
Throttle body of course the other hoses are just vacuum, I said they are connected from the heater hoses T to the intake, there's only two.
Old May 29, 2007 | 01:50 AM
RangerPilot
As I said, to prevent throttle body icing, though it's much less of an issue nowadays as compared to the carb days. It doesn't do much when the truck is warm, frankly it really doesn't do much when it's cold either, but that's neither here nor their. Leave the lines in place, they're not hurting anything.
