The Dyno Results are IN
Old May 1, 2007 | 01:46 PM
54-4U2C's Avatar
54-4U2C
I got a call from Keith Craft Motorsports today that my engine is finished and the dyno numbers are in. They came out at,
HP 567
Torque 575
The engine is a 428 block FE with a 4.250 stroke and a 4.160 bore (461 displacement).
General info:
- Base Engine 428 Block Fully Machined, Scat or Eagle H-Beam Rods, Scat Cast Steel Crankshaft, Diamond Pistons, Plasma Moly Rings, Clevite or Federal Mogul Bearings, Melling Oil Pump, Ford Racing Oil Pump Drive, Stock Front Cover, Remote Oil Filter Mount , Fel Pro or Corteco Gaskets, Stainless Arp Accessory 12pt. Kit, BHJ Damper, Balanced & Blue Printed
- Camshaft Comp Cams Hydraulic Roller
- Cylinder Heads Edelbrock Stage II (CNC work done in-house)
- Valve Train T&D Rocker System, Comp Cams Pushrods and Crane Hydraulic Roller Lifters
- Injection System Very Cool Parts Stack Injection
- Computer F.A.S.T. System w/ Harness
- Oil Pan Canton T-Style w/ Pickup
- Valve Covers Finned Pent Roof FE
- Ignition MSD Distributor, MSD Plug Wires, NGK Plugs
- Water Pump Edelbrock Polished Aluminum
<OI'm pretty happy with the numbers and am one step closer to having the truck I've always wanted.</O
<O</O
<OI think these numbers sound about right for a 1954 F-100. Don't you?</O
<O</O
<ORon</O
Old May 1, 2007 | 02:08 PM
53fatfndr's Avatar
53fatfndr
What preventive measures have you done to your frame/truck to keep from breaking stuff?
Awesome numbers!
Old May 1, 2007 | 02:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That'll have some passing power, but I shudder to think of how much gas it will suck down
Old May 1, 2007 | 02:14 PM
54-4U2C's Avatar
54-4U2C
While the old frame was in good shape, I decided to upgrade to a Chris Alston Chassisworks frame and suspension, with a custom 9" rear end and air bags. It's an IFS up front and a four bar in back. Wilwood 4 piston brakes front and rear, with cross-drilled and slotted 13" rotors.
The transmission is a TKO 600, with a .82 fifth.
Ron
Old May 1, 2007 | 02:19 PM
4tl8ford's Avatar
4tl8ford
I got a 90 HP Flatmotor, unassembled, in the shed
Old May 1, 2007 | 02:21 PM
Randy Jack's Avatar
Randy Jack
Now them is braggin' rights!!!!
You clearly have deeper pockets than I.
Old May 1, 2007 | 02:25 PM
raerjim's Avatar
raerjim
You talkin about Dick, Randy?
Old May 1, 2007 | 02:49 PM
dstruble's Avatar
dstruble
Ron
Yeah I think that MIGHT handle the power lol!!!!! SWEET #'s
Old May 1, 2007 | 03:03 PM
Scott123's Avatar
Scott123
I'm with Dick...for the same amount of money you put in your motor, you coulda had a 100 HP flathead V8. Sucker
Seriously...impressive numbers. Be sure to wake the neighbors a couple of times before you put exhaust on it.
Old May 1, 2007 | 03:22 PM
54-4U2C's Avatar
54-4U2C
I have a better solution on the exhaust. I'm putting on an exhaust gate that will allow me to run straight pipes at the flip of a switch (actually I'm trying to configure it for the choke **** to "hide" it) so I can be real annoying , I mean give me that extra HP if I ever take it to the track.
My neighbors are going to love me.
Ron
Old May 1, 2007 | 07:27 PM
F6Guy's Avatar
F6Guy
A TKO trans!!!!! Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOO WHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOO!!!!!!! Finally someone didn't opt for a pantywaist automatic!!!!!!
Old May 1, 2007 | 08:00 PM
lightning60's Avatar
lightning60
I'll second that!
The TKO is the exact tranny that I am planning for my Lightning killer. I've had two different manuals after swapping out the (non-original) FMX auto that my pickup came with. Neither the M5R2 or the T5 held up behind my (very mild) 351W. The T5 only made it one trip across the country (NV to NY, pulling a trailer) before starting to make some SERIOUS noises.
Old May 2, 2007 | 12:36 PM
brucewolff's Avatar
brucewolff
I love big blocks in these trucks.
The officers will love it too! Keep it cool on the street.
Old May 2, 2007 | 02:20 PM
Gary E's Avatar
Gary E
sounds just about right
We must see pics when it shows up should be really purdy with Waynes stack set up on there.
