56 grill on a 53
Old Mar 2, 2007 | 10:41 AM
dffay's Avatar
dffay
56 grill on a 53
Do the grills have the same bolt hole locations? I like the look of the 56 grills better than the buggy-eyed look of the 53's.
Old Mar 2, 2007 | 10:47 AM
Randy Jack's Avatar
Randy Jack
Yes, the grills have the same bolt pattern. However, the recessed lights in the 56 grill require dimples in the air dams behind them. You will either need 56 air dams or to modify yours by adding cutouts where the 56 dimples are to clear the headlight buckets and wire harness. The parking lights and valance recesses are slightly different also.
Old Mar 2, 2007 | 10:49 AM
LEckart's Avatar
LEckart
The air dams (the panel behind the grill on each side of the radiator) have depressions to accept the deeper headlight location on the 56 grill. You will either need to replace the air dams with the 56 style or cut relief holes or add a relief area to your exisiting panels. I can't remember if the mounting holes are the same but it would not be a big deal to drill new ones if required.
Old Mar 2, 2007 | 10:51 AM
LEckart's Avatar
LEckart
You're just too fast Randy. Good tip on the parking lights also.
Old Mar 2, 2007 | 02:20 PM
dffay's Avatar
dffay
That's what I need guys. Thanks.
Take the rest of the day off.
Old Mar 2, 2007 | 04:42 PM
theGman's Avatar
theGman
dffay, Just thought I'd mention that I did this change on my 55 panel.
I like the frenched headlight look of the 56 grill also.
