chassis specifications car hauler 1947
Old Feb 25, 2007 | 12:24 PM
angrygalaxie's Avatar
angrygalaxie
Red face chassis specifications car hauler 1947
bought a carhauler on a 47 chassis but to get it on the road we need the chassis specifications ,can anybody help me on this
vin 71CC331687 ULADENWEIGHT 3900
THANKS IN ADVANCE ALBERT
Old Feb 25, 2007 | 09:00 PM
46fordtruck's Avatar
46fordtruck
Welcome angrygalaxie, I'll try to help you the best I can here.
The VIN should actually read 71GC331687, which breaks down into a '47 1 ton 6 cylinder truck, which should have a wheelbase of 122".
Exactly what chassis specs do you need?
Old Feb 26, 2007 | 02:54 PM
angrygalaxie
thanks gary for your reply ,what i need is the axle loading capacity so that i might load on the car about 2300kilogram (about 4600 pounds)i think i have the axles of a 1 1/2 ton truck but not sure but i have to show our dmv what the capacity is otherwise i get no title,it,s quit a bit different uphere
The tires are 16 ïnch.the wheelbase is 199.6"
Old Feb 26, 2007 | 03:58 PM
soule46's Avatar
soule46
Gary, am I mistaken or is the 71GC a 1/2 ton (114" WB). From the info I have seen, there weren't many factory styles with a large wheel base such as the 199.6" (The school bus comes to mind). It is very possible that the '47 cab is on a more modern frame. Do you have any pictures. What type of front springs does the truck have coils or leaf? We likely will need more info to help you out with this. Did you get the VIN off the frame of the truck? It is very possible also that the frame was lengthened to make this change (the truck I bought had this done to it, to make a camper).
Charles
Old Feb 26, 2007 | 11:51 PM
46fordtruck
Whoops, Charles, you're correct there, yes, that is a 1/2 ton. My mistake there.
angrygalaxie, that certainly is not a 1/2 ton configuration you have there. The largest wheelbase that was available in the time period was 194" shcool bus chassis which would not have a 1/2 ton truck's VIN. Sounds like you have something that was put together with parts from another vehicle.
The axles from a 1.5 ton would not mount 16" wheels, only the 1/2 tons used 16" wheels, and used a smaller bolt pattern than the 1 ton and bigger trucks. Try to post some pictures in a gallery or someplace online and we'll try to help you figure out what you have.
roguewave
Mar 28, 2017 10:41 PM
mgerdau
May 3, 2016 09:05 AM
big bern
17
Feb 23, 2015 06:15 PM
Gilly47
1947 and Older Ford Trucks
Jul 18, 2014 08:57 AM
OldSchoolRodz
Aug 4, 2008 10:40 PM
