Hopefully a parts wise person on this board can help with a part number. I need the base number for the rear cab mounts for a 64 model F 100. I have a 1967 N 950 that I need rear cab mounts for. Since the N series trucks share the same basic cab as the 61 to 66 pickups. Actually the same as the 64 as it has the step well in the bottom of the door opening. I have a complete set of manuals but for some dumb reason I can not find the rear cab mount. Once I have the number I can go to the basic number in the parts book and see if the pick up mount is the same as the N 950. IF so I can simply order mounts from one of the vendors, if not I guess I will have to use my old ones.
Michelle
1964/72 Ford Truck Parts Catalog, Body Text Section 000, page 13.
See also body bolt location #1 & #2...beginning on page 31 in 000 section. By using the diagram on page 30, you can then go to the different body bolt locations. If a cushion/absorber is listed...something mounts to it. Some of the descriptions say.."use tire carcass!"
There are lots of different basic numbers. Ford calls them an absorber, cushion, etc. There's one diagram...see page 30.
basics: 00154; 00164..etc.
00154 (pg 13) seems to be what you want...use the chart on pg 30.
Thanks Bill, you have been a tremendous help. I am already looking and finding answers. I must have spent an hour looking through the illustration section looking for a picture of a rear or even a front cab mount for that matter to try and get a base number. Couldn't find a single picture. Thanks again and have a great day.
