1940 Ford frame
Old Mar 13, 2002 | 07:54 PM
DightonFord's Avatar
DightonFord
1940 Ford frame
Old Aug 9, 2002 | 02:17 PM
Hi_Tech_ Red_neck's Avatar
Hi_Tech_ Red_neck
1940 Ford frame
Here is my question...
Someone gave me a 1940 Ford frame, I think he said it was from a 4 door or a coupe. My question is, can I get a truck on that frame. I thought they were all the same frame, but someone told me they wern't. I was also wondering where I could find a cab, and all the other little parts to make it go.. one more thing, about the transmision, what can it bolt up to?
thanks for any help
Sean
Old Aug 11, 2002 | 09:47 PM
Carlene's Avatar
Carlene
Admom
1940 Ford frame
Sean - since no one else has responded yet, maybe I can help you out a little.
As for the frame, I don't know if a truck will fit on a car frame, but I do have a diagram of a frame in my gallery (just click the little picture of my truck on the left). Ours is an original 1941 truck (F100) frame which is the same as a 1940 so you should be able to measure your's to see if the measurements match up.
As for the individual parts, I think you would be better off searching for a whole truck rather than to try and put one together piece-by-piece. The original parts are hard to find and the aftermarket parts aren't that cheap.
As for the tranny, if you're using a modern engine, use a modern tranny - same with the rear, axle, etc.
Carlene
Old Aug 11, 2002 | 11:20 PM
Hi_Tech_ Red_neck
1940 Ford frame
Thanks for the help.... It seems to match right up, I think things will work out just right.. Did you guys have to do alot of fab work for the front and rear? Is their much to it? I am looking at getting the frame built, and not worry to much about anything else right now.. I was going to build a tank for it, but wasn't sure of what I have to work with ( clearance for the bed of the truck ) My goal is to have it done by the time I get married ( not real soon )
Thanks again
Sean
Old Aug 12, 2002 | 02:13 AM
staffordra's Avatar
staffordra
Post 1940 Ford frame
horseheavenbob
The passenger frame will work for a 1/2-ton pickup, the only difference being the body brackets that are riveted on. These frames are the same from 1935 to 1940. I have a '35, '36 and '37 pickup, and with these all you have to do to use a passenger frame under a pickup is delete the outrigger ***. body brackets -- the naked frame is correct for the pickups. I'm fairly certain it's the same situation on the '40 (I used to own a '40 sedan delivery).
Hope that helps.
Old Aug 27, 2002 | 11:57 AM
norsman1custom's Avatar
norsman1custom
1940 Ford frame
hi hi teck i got evry thing u need i got the hole truck im parting out soo give me a call 602 692 1674
Old Aug 28, 2002 | 09:21 PM
FortyFords's Avatar
FortyFords
1940 Ford frame
Hi tech ,i own 2 coupes all street rods.
I built these from the ground up all ford drive train.
a few pointers on forty frames,watch out for frame twist,and cracks and rust through at the point the frame kicks up before the rearaxle
Rich
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
