Will theese work
Old 01-07-2007, 09:11 PM
Snowking's Avatar
Snowking
Snowking is offline
Will theese work
http://www.reds-headers.com/html/y-block_headers.html
I got a 57 3/4 ton just makin sure And yes 292 Yblock.
Will they work they should right just wonderin because it i a 250 not 100.
Old 01-08-2007, 07:30 PM
pcmenten's Avatar
pcmenten
pcmenten is offline
From what I've seen, not from experience, the F250 is laid out very similar to the F100.
Short answer is yes, those should work. Obviously, you should try to keep the exhaust away from stuff like the brakes and fuel lines that are under the driver's side floor. Strangely, I've found that exhaust shops are resistant to customer's wishes, so you'll have to be persistent about getting it done your way.
If I had a choice, I'd prefer the tri-y shorty headers like the tbird offering.
Connecticut Calvin
05-05-2016 01:35 PM
chetspencer
13
11-10-2015 08:58 PM
Lagniappe
06-08-2015 06:02 PM
Connecticut Calvin
05-11-2015 03:49 PM
dullchrome
01-22-2009 12:48 PM
Quick Reply: Will theese work
