Wacky guages
Old Nov 22, 2006 | 09:01 AM
askopp's Avatar
askopp
Wacky guages
Anyone care to take a shot at diagnosing this problem. Both my temperature and my fuel guages are acting strangely, and neither are registering correctly. With the truck running, both guages go all the way to their respective end points, i.e., fuel guage says full, temp says hot.
I've replaced the instrument cluster voltage regulator, and at least for the fuel guage I'm fairly confident--but not sure--that the sending unit is working correctly. I don't know how to check the temp sending unit.
Any thoughts?
Old Nov 22, 2006 | 09:17 AM
airharley's Avatar
airharley
Try placing a meat thermometer on the water crossover passage on the intake manifold. Then you can also use it to check your radiator cooling by gentlely sticking it between the fins at the top and bottom near the tanks. That is a waking thought by the way. It may or may not work but the gauge goes up to a few hundred degrees.
Another option is an lazer temp tool. Try not to open the system up since the cap helps to keep the fluid from boiling by increasing the pressure.
Also how are the chassis grounds? Make sure the grounding wires or straps are in good shape. Any kind of corrosion in there will make the resistance go all over the place. The both systems use grounds to complete the circuit.
Old Nov 22, 2006 | 05:12 PM
barry's Avatar
barry
Add a ground from the cluster to a good spot on the firewall or other good metal ground. Make sure the temp sending units on the block don't have teflon tape on the rthreads as it inhibits the ground. With the key on and not running, breifly ground the wire from the temp unit in the block and watch the dash guage. It should go to full. If it does, that eliminates a bad guage. Do the same with the wire from the gas tank unit. If it goes to full, the dash unit is good also.
Is this a recent problem, or has it been going on for a long time? Check the CV unit with a volt meter. Test the side going in, it should read 12V. Then test the other side, it should read 6V +/- . Ford guages are made to work on 6 volts. If you're getting more that 6 volts ( 8-12V) then it's bad. I would suspect that, I've gotten bad ones, especially aftermarket auto parts store ones.
Barry
Old Nov 22, 2006 | 06:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually the gages run on 5V average voltage but you need an oscilloscope to read it. The instrument voltage regulator is like a turn signal flasher unit turning the power to the gages on and off.
When both gages go high like that the cause is the instrument panel voltage regulator loosing it's ground connection or it is bad. Since it has been replaced it is probably the ground connection.
Old Nov 22, 2006 | 09:40 PM
askopp's Avatar
askopp
Ah ha! The voltage regulator is not grounded. In my truck, when I replaced the regulator it was not attached to anything. I've figured out that it should be attached to the instrument cluster. I'm looking forward to trying this out in the morning.
Old Nov 23, 2006 | 08:04 AM
banjopicker66's Avatar
banjopicker66
I've got a couple of spare clusters to look at, if you want to come over.
Old Nov 23, 2006 | 08:37 PM
askopp's Avatar
askopp
Well no such luck. I cleaned all the contacts, and attached the regulator to a good ground. Now the guages don't register at all.
Banjopicker--I got your phone message. Thanks, I'll give you a call, and I would love to drop by Friday or Saturday at your convenience. Regards.
Old Nov 23, 2006 | 08:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
The voltage regulators have three terminals. One is battery voltage, another goes to the gages, and the third one is the case that goes to ground.
With full voltage going to the gages it is possible they are burned out or the senders damaged..
Old Nov 23, 2006 | 08:59 PM
askopp's Avatar
askopp
Yes, I think I have it wired/connected to the cluster correctly. I note that the two wires to the regulator are a male and a female spade so it's kind of hard to mess that up.
Old Nov 23, 2006 | 09:16 PM
norvillebob's Avatar
norvillebob
I have this issue also. When you key on does your ALT light go on. My oil light goes on but not the alt. I measured groung to the socket and it's good and voltage that good the lamp is good. I think I have a ground ing issue. I know good ground good voltage I should have a light but no.
I did get it to light up if I ground lamp to cluster?? I have 2 un-connected wires back there. One is black and the angled style the other is a barrel type.
I wonder if the cab is grouned to frame or is the fuse box supposed to ne grounded??
I'm not trying to hijack, but add things I've done.
Am I assuming correct that "key on" should turn on the alt light???
please post if you get it.
bob
Old Nov 23, 2006 | 09:28 PM
askopp's Avatar
askopp
Bob,
I just walked out to my truck. With my key in the "on" position, but with the truck not yet started, I have both the oil and the alt lights lit in the dash.
