No Power on hills- 7.3 Non-Turbo
Old Nov 14, 2006 | 06:30 PM
mfd591's Avatar
mfd591
I have an 90 F-450 Wrecker with a non-turbo 7.3 and a 5spd that has no power on hills. Empty, loaded same thing- Dangerously slow(lucky to maintain 25mph). Runs fine otherwise, no problem on the highway, stop lights, 12mpg. Has new fuel filter and K&N air filter, 3" magnaflow exhaust. Any suggestions would be helpful. Thanks
Old Nov 14, 2006 | 09:17 PM
PLC7.3's Avatar
PLC7.3
What rear axle ratio......... what RPMs were you turning.........what gear were you in.
Old Nov 14, 2006 | 10:06 PM
Dave Sponaugle's Avatar
Dave Sponaugle
mfd591,
Welcome to FTE and the IDI diesel forum.
Old Nov 14, 2006 | 11:40 PM
mfd591's Avatar
mfd591
no power 7.3
Not sure on the axle ratio. I know It was changed at one time to get higher speeds on the highway without high revs. Not really sure on the Rs going up a hill, I usually cant make it past or have to downshift in to 2nd or 3rd and the Rs are high. Short hills are not that big a deal but its long hils that kill it.
Old Nov 15, 2006 | 10:13 AM
Spectramac's Avatar
Spectramac
Is this a new problem or has it always been a dog?
Get the timing checked, and if that doesn't work, maybe it's time for a new pump and injectors.
Old Nov 15, 2006 | 10:40 AM
mfd591's Avatar
mfd591
no power 7.3
Thanks for all the suggestions every one. In answer to your question Spectramac I bought the truck recently but was told by the previous owner it was a dog on hills so I assume it been an on going problem. I see you are in Monroe I am in Arlington. Any suggestions on a good Diesel shop?
Old Nov 15, 2006 | 12:58 PM
Spectramac's Avatar
Spectramac
Oh a local!
My Dad and I have a shop, but we are pretty busy building engines at the moment. If you get around Monroe at all we could take a look at it and give you an opinion or two. We could stick a light on it and see what the timing is set at. I'll send a PM to you with my number.
I would also recommend Northland Diesel Service up in Bellingham for any pump/injection work you need done. That's who we've got our pumps through for years with no problems.
Old Nov 15, 2006 | 07:53 PM
Dave Sponaugle
Sounds like another NW IDI meeting is in the works.
Old Nov 15, 2006 | 08:28 PM
Spectramac's Avatar
Spectramac
Ha! Yes it does!
Old Nov 15, 2006 | 09:42 PM
Barehuggs's Avatar
Barehuggs
NWIDI Sounds like a sub chapter to me!
