Sponsored by: Auxito
wierd drone/vibration under heavy acceleration
Old Oct 28, 2006 | 09:14 PM
006f350diesel's Avatar
006f350diesel
my brother inlaw has a 2000 2wd 4.6. it has a weird drone/vibration above 3500rpm. it does it in park (very little) but is very very noticeable when in drive. its not a missfire it has new plugs,fuel filter,tranny fluid changed. the tranny doesnt slip and it shifts firm. i dont think its a drive shaft or u joint because you can cruise at any spped and its smooth. its only when you are stepping into it. any help would be appreciated
Old Oct 28, 2006 | 11:07 PM
Dialtone's Avatar
Dialtone
If not u-joint but seems torque related, then I would be looking at the motor/transmission mounts to see if one was broken or loose.
If not there inspect the front of the engine for drive belt/idler/bearing related items.
