Need info on 1934 ford p.u.
Old Oct 9, 2006 | 07:51 PM
54 gene's Avatar
54 gene
Hi I am looking for info on 1934 Ford trucks vin and how many were made and more less the history of the truck thank you all very much.
Old Oct 26, 2006 | 03:21 AM
BADCAR's Avatar
BADCAR
need INFO on 1934 Ford Pu
54 Gene--I dono? on how many were Made? but the Vin Number is on the Drivers Side Frame Rail-just Forward of the firewall--between the firewall & the Steering Box--it will start as a STAR--followed by Numbers--& End also w/ another STAR!--& the number can also be Found on the Transmissions Bell Housing! just Above a All most Square Inspection Cover!--hold On by Two large Screws--& when 100 % Stock--Both Number were the SAME!--the VIN & Tranny!--& it the Trannies Differant? the Trannies been Changed! & if? Your Attempting to Register It? & can*t SEE! the Numbers on the Frame Rail?--Use the Numbers on the Bell Housing!--for VIN ID purposes! as the Frame Numbers DO get Pretty Rusty & hard to SEE!--but The Trannies Cast & is Protected by the Body--& a Lot Easyer to SEE!-I Hope this HELPS?--Ole JIM--
mydoit
1947 and Older Ford Trucks
Apr 12, 2015 12:43 AM
007brian
New Member Introductions
Mar 1, 2015 12:03 PM
texczech
Feb 5, 2015 09:17 AM
JPMallory
Oct 10, 2014 07:16 PM
edtahaney
Jul 19, 2014 04:19 PM
