EGR - DPFE - reset computer question
Old Sep 20, 2006 | 08:32 PM
boffah's Avatar
boffah
So I've been reading up on the P104 error.... I decided to measure the DPFE sensor voltage between the top two pins with the key on and engine off... the DPE sig read read 5V (BAD)
per http://rockledge.home.comcast.net/Ra...tage-Test.html
I run down to Autozone and connect up the plastic one ( #su2108 ~$39) and it starts running real rough. When I disconnect the electrical connector on the new DPFE, there is no difference? When I put the old part back on, same thing no difference.
Am I supposed to reset the computer by disconnecting the battery for an hour or so after putting on a new DPFE?
Old Sep 20, 2006 | 11:27 PM
buzzard's Avatar
buzzard
In your case, I'd definitely disconnect the battery for 10 or 15 minutes (one hour is not necessary).
Old Sep 21, 2006 | 04:49 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Disconnect the negative cable... touch it to the positive cable (which is still on the battery) for ten seconds... then reconnect the negative back to the battery. That should do the trick.
Don't expect it to run perfect for a few miles, as it'll have to relearn everything.
Good luck.
Reuel
Modular V8 (4.6L, 5.4L)
48
Jul 4, 2021 02:25 PM
SteelHorse4x4
Apr 9, 2017 12:12 AM
jjsfamily
Jul 2, 2014 12:13 PM
wiredcur
1997 - 2003 F150
Apr 6, 2009 06:23 PM
