im changing the rear end gears what do yall suggest
Old Jul 31, 2006 | 07:54 PM
leftystar's Avatar
leftystar
Question im changing the rear end gears what do yall suggest
Right now i have 3.08 gears I want to race a little its still a weekend truck b/c i have a work vehicle but its kinda a everyday driver ive thought about 3.73 do i need lower or higher gears or what have yall used
Old Jul 31, 2006 | 09:18 PM
andym's Avatar
andym
It depends on what size tires you have on it. It also depends to a degree on whether your transmission has overdrive, what your top speed is, and what kind of mileage you expect out of it.
Old Aug 1, 2006 | 09:18 AM
smallblock351w's Avatar
smallblock351w
my truck originaly came with 2.73 gears. It has a c6 in it. i switched to 3.50 gears at one point pretty good all around gear. I just recently went to 4.11 gears and i like it allot but the motors more built for it so the cam likes those gears. If you have a c6 i wouldnt go lower then 4.11 if your running stock size tires or you will really be tacking that motor down the highway. Mine tachs around 3400 at 65 atm
Old Aug 1, 2006 | 03:20 PM
MBBFord's Avatar
MBBFord
Like previously mentioned, there are a couple factors that come into play for somthing like that, but 3.73 would be a good ratio for better acceleration, and still decent RPMs on the hwy with a stockish truck.
