40-41 and 42-47 122" wheelbase frames
Old Jun 26, 2006 | 04:28 PM
Stovebolt's Avatar
Stovebolt
Are the 40-41 and 42-47 122" wheelbase frames exactly the same? If so, can the 40-41 3/4 and 1 ton front end sheet metal bolt up to the 42-47 frame and cab without modification? Thanks.
Old Jun 26, 2006 | 09:03 PM
46fordtruck's Avatar
46fordtruck
While I have never had the chance to compare them side by side, looking at the Ford Chassis Parts Catalogue (a.k.a. "The Green Bible") I find that there are different part numbers used by Ford for the frame assemblies, and the front crossmembers are different. Appears that some of the middle crossmembers are the same, but the crucial ones for your swap, the fronts are different. I would think getting it attached to the cab is the easier part of the 2, the frame would be more of a challenge.
Rickster800
1947 and Older Ford Trucks
33
Dec 28, 2016 09:34 PM
351coupe
18
Jan 5, 2016 02:49 PM
willowbilly3
Dec 3, 2015 06:06 PM
willowbilly3
Nov 10, 2015 08:24 AM
havi
Nov 3, 2013 05:15 PM
