Rear Brake Drum Removal 46 1Ton
Old Jun 23, 2006 | 04:57 PM
Tom Lane's Avatar
Tom Lane
Cool Rear Brake Drum Removal 46 1Ton
Can someone walk me through steps to remove Rear Brake Drums on 46 1 Ton. Thanks!
Old Jun 24, 2006 | 06:48 AM
sosotwo's Avatar
sosotwo
if it is a full floating rearend you have to remove the bolts that hold the axle in about about 8 bolts in the very center of the rim area pull out the axle the front bearings will come out at this point if the brakes are not seized to the drum it should pull off
good luck
Old Jun 26, 2006 | 07:19 PM
loholland's Avatar
loholland
Is your truck a pickup style 1 ton with single rear wheels like the one in Gary's Gallery or a dual wheel type?
Old Jun 26, 2006 | 07:47 PM
Dan Robertson's Avatar
Dan Robertson
There may be nuts holding the axel in place rather than bolts. If so, there should be a lock under each nut. Just loosen all of the nuts up but dont completly remove them. With all of the nust loose, hit the center of the axel with a heavy hammer. You have to hit it quite hard. The jar should loosen up the locks and the nuts hold the locks from flying to parts unknown. Remove the locks and the nuts and the axel should pull right out.
Old Jun 26, 2006 | 08:55 PM
Tom Lane's Avatar
Tom Lane
Hub Removal 46 1 ton
Thanks very much for all the help! Hope to return the favor someday.
gravdigr
Jul 6, 2015 02:40 PM
Mitch1129
May 23, 2015 10:43 PM
Garrett Fuchs
1947 and Older Ford Trucks
Mar 14, 2015 04:24 PM
cybeast
Jan 18, 2015 09:11 AM
Blackwaterforge
May 1, 2014 07:19 AM
