sluggish 351w after rebuild
Old Apr 29, 2006 | 07:49 AM
78 Ranger's Avatar
78 Ranger
i just rebuilt my 351w this winter and when i put it back into the truck it had a little hestitation when i stomped on it so i had the holley card rebuilt and now it works better but it doesn't have any more power than it did before. i put an rv cam in, new oem pistons, ground out smogbumps, had a profesional valve job and new lifters and new valve springs, plus all new bearings and seals. i really expected some more power. i have noticed lately though that when in 4x4 and starting away in first gear there is a little spark knocking. i'am wondering if the timing should be advanced or retarded for the new cam i put in
Old Apr 29, 2006 | 08:06 PM
roger dowty's Avatar
roger dowty
what is the compression ration of your build- retarding timing will affect power neg and obviously help detonation but thats something to play with.
Porting can be very helpful or it can hurt low end grunt if the porting increases volume at the cost of velocity. Also Holleys can be hard to set up correctly. Since I'm definitely not good at settng up the fine aspects of a build like timing and carb I plan on using a dyno and an expert- should be well worth the $$.
I'm a 335 guy learning myself as I'm building a W right now- or at least have it out and torn down...
Old Apr 29, 2006 | 08:59 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Were they dished pistons cause I would have used flattops, compression makes power.
Old Apr 29, 2006 | 09:40 PM
roger dowty
could be cr isn't the culprit but a lot of folks either build or have engines built with parts that do not make the most out of the 87 they slurp. Compression and quench are funny things and I'm still looking for folks who talk about that on this forum...search's aren't giving me much to go on.
Old May 1, 2006 | 10:18 AM
Kemicalburns's Avatar
Kemicalburns
what are the cam specs. whats the timing set at now? what intake manifold are you running?
jborushko
17
Dec 6, 2011 10:54 AM
94bonestocker
May 16, 2011 08:01 AM
70velle
Apr 27, 2004 10:30 AM
84bronc
1978 - 1996 Big Bronco
Feb 13, 2004 03:30 PM
Todds79
May 5, 2002 04:32 PM
