Problem with a 96 Ranger
Old Apr 9, 2006 | 05:14 PM
AKpilot's Avatar
AKpilot
My truck has a studdering problem. It doesn't happen all the time, seems to happen more when the truck has been driven a lot in one day, and it seems to happen more at low RPM's. With the clutch pushed, if I press down on the gas the RPM's drop drastically and the engine studders like it's going to die but it never does. The same happens when shifting gears. If I slam on the gas it works through the studdering and the RPM's jump up like they're suppose too.
I've replaced the fuel filter, Crank Angle Sensor, and the DPRE Sensor in the EGR System. I've also dumped Fuel Injector Cleaner into the gas tank the past couple fill-ups. Nothing seems to work. My next guess is the fuel pump or possibly a short in the Ignition Wires.
Anybody have any thoughts?
Thanks...
Old Apr 9, 2006 | 05:27 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Engine size = ?
Have you tried pulling codes? If you're able to get the engine to high revs without a power loss, it's probably not a fuel pump issue (starvation).
Old Apr 10, 2006 | 06:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome AKpilot to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
