Anyone with a parts book?
Old Apr 2, 2006 | 03:03 PM
3Mike6's Avatar
3Mike6
Maybe could tell me if '42-'47 front shock mounts are the same that came on the '48-50 F1 trucks?
Reason I ask is the original front mounts are not on my '42.
If anyone has a parts book that could at least give me the part number, then I could repost on the '48-60 forum for the same info.
Thanks.
Old Apr 2, 2006 | 09:57 PM
45ford's Avatar
45ford
'42-47's used lever action shocks.
That being said, the '48-52 axle is the factory replacement for the '42-47 and is identical except that it has a built-in lower-shock mount boss.
I ran a dropped F-1 axle with '48-52 shocks & mounts for a number of years in my '45.
Mike
Old Apr 3, 2006 | 11:20 AM
3Mike6's Avatar
3Mike6
Thanks for the information, I'd guess the upper shock mounts would be different as well then between the 42-47's and 48-52's.
Now the search begins...
Old Apr 3, 2006 | 05:49 PM
User 71024's Avatar
User 71024
Thanks.
I'm replacing the front shocks on my 46 with modern shocks, what parts are you looking for? I may have them for you. acrad(at)adelphia.net
Old Apr 3, 2006 | 07:37 PM
46fordtruck's Avatar
46fordtruck
There isn't an upper shock mount. The arm, sometimes called a dog bone, connects between the arm on the Houdaille shock and the shock/rubber bumper bracket on the axle. Those parts are 42-47 specific. You can use the passenger style tube shock bracket to add tube shocks to these trucks. That's what I have on my trucks...big improvment over the Houdaille shocks.
Old Apr 4, 2006 | 05:45 AM
User 71024's Avatar
User 71024
That's why I asked what parts he needed, I thought the shock bolted directly to the frame on mine. I thought I had forgotten something.
Old Apr 4, 2006 | 07:34 PM
3Mike6's Avatar
3Mike6
I see...see, on my '42, someone bolted some type of mount on the frame and then installed a regular shock.
So, maybe they just used the original holes? I dunno, I'll have to look closer.
Does the original shock attach with two holes to the frame?
Eric,
Let me know what you want for your shocks.
Thanks.
Old Apr 4, 2006 | 07:37 PM
46fordtruck
The original shock just bolts right to the 2 holes in the frame. There were many aftermarket adaptor for putting tube style shocks on, most probably used the original mounting holes.
Old Apr 4, 2006 | 08:02 PM
3Mike6's Avatar
3Mike6
The clowns that did mine did a little "freewheeling", and cut out a portion of the fenderwell for mount what they had.
