fuel pressure monitor circuit help please
1994 Explorer 138K on the clock.
I continuousdly get the KOEO code of 543.
Had CM of 543 but erase it.
So I am tracing a monitoring wire to the pcm.
Fuel pump runs and I have no issues. buT I am trying to locate were the DG/Y wire goes from the distribution to the PCM.
Where is the PCM and what is the routing from the distribution block?
ANy place in particular subjective to corrosion on this wire?
I am getting power to the pump, but the pcm is NOT seeing the power.
What gives? PCM going bad?
I ran a engine running test after warm up, and I still get a 543 code in KOER or in the KOEO (prior to seperator pulse).
