crossmembers do not leak, transmission rear seals do though.
wipe everything down and the take for a short drive and look to see if you can identify leak.
could also be a cracked case.
i know a steel crossmember does not leak...im just saying that is where it is dripping off of. ill wipe things down and see if it comes from the rear seal or from the plugs on top. i dont think its from the plugs because it leaks like a son of a b|tch when parked.
thats a great link...and that is where it is leaking from. i was home this past weekend and i ripped it apart to see if thats where the leak is coming from and it is...again, thanks much!!!
