7 prong/4 prong Super Duty Plug
Old Jan 23, 2006 | 07:31 PM
Studenut65's Avatar
Studenut65
Hello all,
I have a 99 F-250 Super Duty Reg Cab with a V-10. Currently, it has the factory flat four trailer wiring plug on it. I would like to know if I can unplug this from the trucks wiring harness and plug in a factory 7 prong/4 prong plug that the newer super duties have. Thanks in advance.
Nate
Old Jan 23, 2006 | 08:24 PM
DaveBowman's Avatar
DaveBowman
I also have a 99 and the 7 wires for the RV plug were all capped off and zip tied up to the harness. You might want to check if yours are too.
If not, you cant un-plug the 4 wires and plug in a 7 pin because you don't have a few wires you need for the 7 pin (reverse light, accesory, and brake control)
Old Jan 24, 2006 | 08:47 AM
Studenut65's Avatar
Studenut65
Dave,
Thanks for the reply. I will check for the wires under the truck when I get home. Hopefully they are there. Thanks again.
Nate
