Rebuild or Buy New Carbureter..500 or 600?
Old Jan 6, 2006 | 09:01 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I will be running a 350 cruiser engine with an automatic in my 48 F-3. I am not interested in high performance or racing but I am interested in gas mileage. I will be running an Edelbrock Torquer manifold. I have a 600 CFM Holley electric choke carburetor that I picked up used and it has not been run in about 5 years. It appear okay but it is missing a piece of linkage that opens the rear barrels.
My question is this. Should I have the Holley rebuilt (I'd have hire it out since I know nothing about rebuilding a Holley) and try to find and replace the piece of missing linkage or should I just buy a new carburetor?
I don't want to spend a lot of money on this Holley, find out it is junk and have to start over. If I buy new I was thinking of going the Carter or Edelbrock route with either a 500 or 600 CFM carburetor or possibly another Holley 600. Which carburetor and venturi size would best suit my means? Thanks for your comments...
Vern
Old Jan 6, 2006 | 05:36 PM
Franklin2's Avatar
Franklin2
If you have to pay to get it rebuilt, then buy a new one. The 500 or 600, any brand, will work good.
Old Jan 7, 2006 | 10:04 AM
LxMan1's Avatar
LxMan1
I would use a 500 cfm Edelbrock, but loose the torker manifold. It's power band is 2500-6500 rpm and will not give great throttle respnose or the best mileage due to it being an open plenum manifold. You would be better off with a Performer dual plane intake or any dual plane intake.
Old Jan 7, 2006 | 10:58 AM
GreatNorthWoods
Jimmy,
Thanks. I am using the Torker only because I already had it and did not want to buy a new one right now. Plans are to replace it with a Performer when I have the cash. I had this same intake manifold on a SBC 400 with a 600 Holley and got about 14MPG with it.
Old Jan 7, 2006 | 05:51 PM
LxMan1's Avatar
LxMan1
That's cool. I would Go with the Edelbrock carb for now and it may help to use a 1" 4-hole spacer.
