Can I put 35 spline where 16 was?
Old Dec 18, 2005 | 10:38 PM
edwardldog's Avatar
edwardldog
Can I upgrade my 16 spline housing (Rear D60) to a 35 spline axel?
Old Dec 19, 2005 | 09:09 PM
teds74ford's Avatar
teds74ford
It isn't just a bolt in. I looked into a 35sp lockrite, but had to shave the insides of the spindles to get the axles in. However, a 30 spline is a direct bolt in- assuming you have a 30 spline something in the diff.
Old Dec 20, 2005 | 01:39 AM
edwardldog's Avatar
edwardldog
oops My Bad can I take the D60 with 16 spline Axel Shafts and replace them with 30 spline axel shafts if I replace the carrier?
Old Dec 20, 2005 | 08:29 AM
teds74ford's Avatar
teds74ford
That's what I did. I wanted a lockrite, and got a set of 30 spline axles for $10. It was straight foreward. Of course, you could swap the spiders in an open diff, but I can't see what benefit a 30 spline open would be over a 16 spline open.
Old Dec 20, 2005 | 10:08 PM
chrono4's Avatar
chrono4
not much, unless you bust out that mig and weld 'er up.
Old Dec 20, 2005 | 10:14 PM
edwardldog's Avatar
edwardldog
so what are you beating around the bush about? are you trying to tell me I can't buy 30 splin axels and a 30 slpin locker and install it?
Old Dec 21, 2005 | 03:45 PM
chrono4's Avatar
chrono4
no, i was sayin your should instal it all, and then welder up, save a few bucks, unless its on a dd.
Old Dec 22, 2005 | 01:28 AM
edwardldog's Avatar
edwardldog
Yeah A couple folks said the same thing but it's in my trail rig and I want to be able to get it home when it brakes
