94 4.0L Fan Clutch help ...
Old Nov 9, 2005 | 12:00 AM
swifty_2_2's Avatar
swifty_2_2
NAPA and Ford tell me that there are two differnet fan clutches for my Ranger, a "standard" and a "heavy duty". They also say not to put a "heavy duty" fan clutch on a vehicle that had a "standard" fan clutch. My old fan clutch was aftermarket so no chance on matching Ford part numbers.
Anyone know if the "heavy duty" fan clutch has anything to do with the the super cooling engine option? If so, how do I tell if my engine is super cooling? From my VIN it shows 4.0L 6Cyl OHC.
Thanks
Old Nov 9, 2005 | 08:24 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Basically, the two are air condition and not air conditioning. If you have an a/c condenser the air has to travel through the condenser and radiator to get to the fan clutch bi-metal, so there are two different clutches.
Old Nov 9, 2005 | 09:09 AM
RangerPilot's Avatar
RangerPilot
so the HD one would be if you have A/C?
Old Nov 9, 2005 | 11:01 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
That's right. You will need a large flat open end wrench to remove the fan clutch and a second open end larger wrench that slides over the 4 bolts on the waterpump pulley to hold the pulley while you remove the clutch. Sometimes you can use a strap wrench to hold the pulley and a giant pair of what I always call water pump pliers to turn the clutch. I have heard that some auto parts places will loan you the tools.
