Info about my truck
I think it's a 1946
all i do know for sure is that its a fire truck
the code I have is C698T81-H12923 does anyone know what that breaks down to
Thanks,
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
C = Canada
69 = '46
8 is likely powerplant - what engine do you have in it? The only other 46 Can vin I've seen had a '6' here.
T is likely one ton or larger
81 = standard cab/chassis
H = Home Office (Ontario) assembly plant
12923 = serial number
That's the best I can do. I could be all wet. But the numbers in the string are similar enough to the later ones that this is my best guess.
