Fuel Injectors Only On 1 Side?
Old Oct 23, 2005 | 09:15 AM
weverette1's Avatar
weverette1
Unhappy Fuel Injectors Only On 1 Side?
Left Side Injectors Aren't Firing..
What Should I Do?
Please Help!!!!
Old Oct 23, 2005 | 06:09 PM
EPNCSU2006's Avatar
EPNCSU2006
year, make, model?
Check computer for codes is where I would start. See if that turns anything up, then start looking for burned or cut wires.
Old Oct 23, 2005 | 06:45 PM
weverette1's Avatar
weverette1
1989 Ford f-150
I don't remember the shadetree way to check the codes, do you?
Old Oct 23, 2005 | 08:04 PM
EPNCSU2006's Avatar
EPNCSU2006
Sure do . Check out this website for some helpful diagrams and code definitions: http://www.thorssell.net/hbook/eectest.html . Let us know what you turn up.
The way the injectors are wired on that truck is in groups of four: 1,4,5,8 as one group and 2,3,6,7 as the second group (I assume a V8 since you said left injectors). If all four on one side are not firing, then none of the injectors are firing because of the way they are grouped. There can be several wiring issues that would cause this problem. I would test for 12V on the red wires of the injectors with the key on, engine off. Let us know what you find. Do you know if you are getting spark to the plugs?
