NP435 into 7.3 Diesel Super Duty
Old Oct 11, 2005 | 10:56 AM
bigblue's Avatar
bigblue
Will the NP435 from my 86 F150 inline 6 be a direct swap into my 95 Super Duty with 7.3 Diesel?
If not, what is needed?
Thanks
Old Oct 11, 2005 | 02:04 PM
andym's Avatar
andym
You'll need a new bellhousing from an NP435 that was behind a diesel or a 460. You'll also need the crossmember for the NP435.
Good luck, sounds like a fun swap.
Old Oct 11, 2005 | 06:59 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
One thing you're also going to want to consider is the rear axle gearing. With a 1:1 ratio in 4th gear, your 7.3L will be spinning some hella-high RPM going down the highway.
Cody
Old Oct 12, 2005 | 09:57 PM
Franken-Truck's Avatar
Franken-Truck
The 460 and Diesel have different bell housing bolt patterns. The gas NP435 has a wide ratio gear set, while the diesel version (if there is one) has the close ratio gear set. With a gas tranny behind your diesel, you'll rev way out of your power band and be shifting way too soon (unless you have like a 3.00 rear end). . . just an example, the 1st gear in your NP435 is 6.69:1, while a diesel is around 4:1. Cody brings up a good point about no overdrive. Also, if your swapping out a ZF for whatever reason, you'll need to more than likely modify your drive shafts, come up with a custom crossmember, and you might have difficulty adopting a slave cylinder setup to activate your clutch (external slave). If your swapping out an auto. . .then you'll have all kinds of problems to deal with.
I'd keep an eye for a proper replacement
Old Oct 13, 2005 | 09:12 PM
Briansshop's Avatar
Briansshop
I was looking into the same combo.The most I could find out was bell housing patterns are different-only the top two bolts are close.
1mouse3
18
Apr 4, 2022 10:04 PM
bbf ford
Oct 13, 2013 11:39 AM
Rusty_Old_F250
Sep 13, 2013 08:06 PM
ralf
Feb 26, 2007 08:30 PM
inliner
13
Jul 16, 2001 06:53 AM
