The steering column tube can be removed with the steering box still mounted in the truck.
For anyone who doesn't know the tube is flared on the steering wheel end and the bracket that holds the steering column in place does not slide past the flare.
If you have ever tried beating your steering wheel off it is a lot easier to drill and tap holes as suggested here and use a puller.
