Two Crews Are Better Than One
Now I need some ideas. I am not one to leave well enough alone so, I am planning some updates.
Thinking about swapping the chassis over to one of those late 70 trailer special frames, that everyone seems to like so much. If I can find one of the 139" wheelbase ones, I could probably get away with shortening the bed about 6" and everthing may just line up.
Need some drivetrain suggestions. The 240 six and the granny tranny is pretty anemic. The truck will be used for a daily driver and to pull some trailers under 8000 #. (needs decent MPG and torque) Here are some parameters I am thinking about.
Engine- 351w maybe. 302 not enough, 460 to much. Probably efi, I never learned how to tune a carb.
Tranny- Auto, I do have an AOD in the garage I may use.
Gears- to match the engine and tranny
Wheels- 17x8 with 30 or 31" tires
Budget- $2,000 using basic rebuilt or late model salvage parts.
Thanks for the input, Matt
That ol truck has been back & forth across the country. I have seen pictures of it several years back. It does need a new suspention under it, since it wouldn't haul an FE engine out of NC last winter.
Happy hunting & project working
John
Thanks, Matt
Congrats on the crew...glad to see it went to someone who will appreciate it as much as cappy. the frame mounts you have will need new front frame mounts and new outboard ones. the bottom of your cab will be very similar to your crown. just done a lot better LOL.
I used a 79 Heavy 150 trailer special chassis on the suicide crew. made some new front mounts and added a rear mounts outboard to pick up the back. They run close as the 79 frame widens out but that should not be a problem for you. with the added legenth it,may end up right on top of the frame rail.
I made a custom legenth bed to fit the wheelbase. so the only thing i could suggest is a little stretch of the wheelbase or modify the bed shorter.
Garbz
What size wheelbase are you using on your crew and what length is your bed now? I was wanting to make it a 139" wheelbase, like the newer crews have with the 5 1/2 foot beds, using a regular cab, long bed frame with the 139' wheelbase. The Supercab frame I have for the Crown is 154" and I really dont want to cut the frame, so I am looking for something shorter.
An interesting note, the Ford Cab is 2 1/2" longer than the Crown.
Matt
