Turn switch ON. When the safety belt warning light goes off do the following with in 1 minute. Buckle and unbuckle the driver's seat belt 3 times then turn the headlights on and off. Buckle amd unbuckle the seat belt 3 more times. After that the warning Light should come on for a few seconds. As soon as it goes out buckle and unbuckle the belt. This should work.
If you put your seatbelt on, the alarm turns off. Easy as that.
Actually that's not true. Once the wonderful beltminder feature decides to sound, even if you get the belt plugged in before the sound starts, you get at least once cycle of the buzzer. That is what convinced me to disable mine.
My 03 Ezb doesnt require all that. After I drive for about 1 min. with the seat belt on, all i have to do is take the seat belt off and the buzzer does not engage. I dont have to insert it 3 times....
WHat you are talking about is temporarily disabling the minder. The complicated method disables belt minder until you re-enable it.
