1978 - 1996 Big Bronco
strange ignition problem
Old Apr 12, 2005 | 07:15 PM
swheten's Avatar
swheten
Question strange ignition problem
Hey, I have a 81 Bronco with a 351M in it. When I turn my key to accessory the engine starts turning over. I've replaced the ignition switch, pulled the steering column apart and nothing seems to be out of place or worn. So if anyone has any thoughts on what could be the problem, please let me know! Thanks!
Old Apr 13, 2005 | 06:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 15, 2005 | 09:33 PM
Capone's Avatar
Capone
check the ignition switch contact point for bridging...it sounds like the start circuit is getting juice when the key is on acc...also check to see if your ign switch plug is on right.
let us know what you find
