Fenderwell Exit and a crossover
Old Apr 2, 2005 | 09:40 AM
StephenKnight's Avatar
StephenKnight
Ok I want to put a crossover or an x pipe in my exhaust system BUT I have to use fender well exit headers, I don’t really want to route my pipes under the frame rails, if I high center I will most definitely crush my pipes, I’m thinking if I route between the frame and cab I wouldn’t be able to sit in there for long (noise) plus the rubbing it would cause, I was thinking maybe cutting holes and welding in some thick wall tubing thru the frame rails. The big but here is the last time I welded on the frame (my last truck) these spots became prone to cracking (then again the opinion of some was that I made my frame too stiff and didn’t allow for enough flex, the entire frame was boxed)
Old Apr 2, 2005 | 10:06 AM
buzzbait65's Avatar
buzzbait65
I was wondering about this myself, not having a body lift leaves little room, if there were a body lift though you could just flatten a section of pipe a little bit and put that between the frame and body from the outside of the frame to the inside. I have heard that the x-pipe and balance tube help quite a bit in different areas
let us know what you come up with if you do
Old Apr 2, 2005 | 10:21 AM
StephenKnight
well i got a 6 in body lift but im puttin 4 in pipes in that leavs verry little room and i dont want the rub
Old Apr 2, 2005 | 10:28 AM
buzzbait65's Avatar
buzzbait65
that is plenty of room, even with a little engine movement.......which i would try to keep to a minimum anyhow
with 4" pipe you could 45*or 90* between the frame and cab then into the x pipe, depending on where your t-case is, for clearance
Old Apr 2, 2005 | 10:34 AM
Franken-Truck's Avatar
Franken-Truck
6" body lift
Why not run a 3" balance tube, or a 3" and 2" parrallel. The 3/2 combo would only have 19% less cross sectional area than running a 4" pipe. 2 3" tubes would be bigger than a single 4", but maybe that doesn't matter?
Good luck
Old Apr 2, 2005 | 10:47 AM
StephenKnight
Yep 6 in
Gotta have 3 in so the 429 fits. gona put 49 in tires so i need the clerance plus i cant go over 30 in at the lowest point in the frAME
HighdefJoe
Aug 15, 2008 07:53 PM
rsylvstr
All Things Towing
16
Apr 24, 2007 07:48 PM
Cybertaz126
1978 - 1996 Big Bronco
Apr 12, 2007 11:19 PM
pronstar
Exhaust Systems
Apr 16, 2006 08:43 PM
