need to ID.
need to ID.
i can not find any numbers on my axles at all no plate no part number except on the knuckels.they look like dana60 in the rear and 44 in the front but i just can't tell for sure. any other ideas. they are under a 77 high boy if all my iding is right for a highboy.if i remember right it has a 28in.wide frame.so any one know of a differant way to tell witch axles i have.
IF this is an F-250, it should have exacltly as you suspect. 44 front, 60 rear. A 60 could be optioned for the front in a couple of ways. Easiest way, you can measure the axle tubes, 44 is 2.75" and the 60 is 3.12". There are numbers cast into all our dana,s but they can be hard to find. Most of them it is cast into the webbing between the coverplate and the axle tube. (Often right under the spring u-bolt) Some it is found on the snout behind the pinion yoke, ALL of em, it is hard to see as they fill with grime over the years. good luck with it. -Dale
