ranger frame on 50's ford?
Old Mar 6, 2005 | 09:49 AM
pipkorn_9's Avatar
pipkorn_9
Question ranger frame on 50's ford?
Im new to this all and im only 16 and i was wondering if i could modify a newer ranger strait axle frame/chassi to fit a 1950 ford f3
if any one has any advise for my first rod/rebuild i would appreciate it
Old Mar 6, 2005 | 02:54 PM
j wright's Avatar
j wright
Alot of it would depend on how mechanicaly inclined you are, what tools are avialable to you and how much support you can get from your family and friends. There is an old saying that with enough time and money anything is posible. So talk with your folks and listen (most of them have been down the bumpy road of life and will havve some insight to most problems). If you decide to proceed keep in touch and ask questions along the way, you will get answers.
Good Luck
John
Old Mar 7, 2005 | 01:59 PM
Dodge41's Avatar
Dodge41
The whole chassis swap idea has come up often on FTE, that is why you may not get too many replies about it. Dont worry its a forum and asking questions is what its all about. Many people have not done this swap before and can only produce imformation about it from what they have read and people they have talked to; Im one of those people. There are articles online detailing what people have done and I recommend you search the internet and read what thsoe people have to say. Most people will tell you that it will involve making alot of brackets to mount the body to the frame which takes time and skill with a welder. Newer frames have a dip in the middle, where as older frame rails are straight and this also causes problems. There is a sticky in the 1948 and up section detailing alternatives for front suspension. Its a good read and I recommend you take the time to read it before you decided. Hope this helps and good luck.
(BTW this post is in the wrong section but dont worry it will probably be moved to the 48 and up so the correct people can help you out.)
John-1967
16
Sep 16, 2015 07:09 AM
Michael Karr
Sep 17, 2013 06:21 PM
Wooky71
1983 - 2012 Ranger & B-Series
May 18, 2006 08:11 AM
4T8ford
Feb 28, 2003 02:25 AM
owlfans
Mar 26, 2002 11:19 AM
