Hooking an amp up to PA speakers?
I'm getting a CB with a PA setting and I want to hook up a PA speaker or 2 to it. the problem is the CB outputs at 4 watts and the pa horns can handle about 25 watts a piece. How feasable would it be to hook up a small amp between the CB and speakers? and would there need to be anything special done to hook it up, or would I do it the same way that I would a set of car speakers?
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
