Sponsored by: Real Truck
frozen rear doors!
Old Dec 21, 2004 | 07:43 PM
sawdust220's Avatar
sawdust220
Angry frozen rear doors!
Hey you guys, Anybody have any tricks to keep rear crew cab doors from freezing shut? Last year it got so bad that one of door handles broke (125.00). I have tried WD-40 on the weather strips,waxing the door jambs, nothing is working. The handle releases,but the doors are frozen shut. Gotta love Michigan in the winter.
Old Dec 21, 2004 | 08:12 PM
yysenhimer's Avatar
yysenhimer
Mine froze yesterday morning and I needed to get a heavy test equipment case out of it. One side wound up thawing out enough to open. At least I had no problems starting it though @ 12 degrees and no block heater plugged in.
Old Dec 21, 2004 | 11:01 PM
utahtom's Avatar
utahtom
Great question sawdust- Mine do the same thing on a rare, very cold occasion.
Hopefully someone will post a solution...
Old Dec 21, 2004 | 11:58 PM
Jokenring's Avatar
Jokenring
Blowtorch
Old Dec 22, 2004 | 06:42 AM
Edmo's Avatar
Edmo
Park in the garage...
However, my CC Longbed will not fit in mine.
I ran into the same frozen door issue when I lived in Anchorage, however my move to Arkansas has elminated that problem. I just have to deal with nimrod drivers!
Edmo
Old Dec 22, 2004 | 09:39 AM
Frobozz's Avatar
Frobozz
If you can get in any door, then opening the remaining stuck ones is better done from inside, perhaps with feet against the door, rather than pulling on those kind of flimsy handle paddles from the outside.
I use Sil-Glyde ( http://www.backglass.org/duncan/sil_glyde.jpg ) on my door seals to cut down on the squeaking from rubbing, I bet that's why I haven't had so much problem with doors icing shut lately. It stays around a lot better than WD-40 and such. (But don't leave it on so thick that your passengers get slimed when they get in the truck!)
Duncan
Old Dec 22, 2004 | 09:57 AM
AuRevoir's Avatar
AuRevoir
I used petroleum jelly(Vasiline)on the rubber seals before, just don't put too much, it worked better than the aerosol lubricants.
Old Dec 22, 2004 | 10:50 AM
Frobozz's Avatar
Frobozz
The problem with petroleum jelly is that it slowly dissolves the rubber. (Ask any shotgun-wedding teen how they discovered that...) Silcone won't eat the rubber, which is why I got the Sil-Glyde.
Duncan
Old Dec 23, 2004 | 07:38 PM
AlaskaPowerStroke's Avatar
AlaskaPowerStroke
What about turning the truck on and heating them from the inside out?
Old Dec 23, 2004 | 07:45 PM
Frobozz's Avatar
Frobozz
That works too, if you have the time. (If you have a *lot* of time, you could just wait until Spring!) Rattling down the road will usually crack them loose too... or maybe that's just the lousy roads here near Chicago...
Anyone still getting windows frozen shut with all that rubber seal surface area on the outside? We used to have to carry a big putty knife with our Excursion, since getting the driver's window down is kinda key at the toll booths. We'd break it loose before setting out for the day. I haven't had that happen with the '03 F250, so I wonder if Ford changed something slightly in the design?
Duncan
Old Dec 23, 2004 | 08:01 PM
Rongold's Avatar
Rongold
Question
How are you going to start the truck if you can't get in it ?????
Old Dec 24, 2004 | 05:17 AM
Apostle's Avatar
Apostle
I had a '76 Cadillac Coupe Deville that the doors would always freeze shut. I would just put a space heater on the floor and put the cord out the door. Then the next time I couldn't get in I would just plug the cord in and let the heater run. It only took a few minutes then I could open the door. Just remember to turn the heater on before shutting the door.
Old Feb 2, 2005 | 04:53 PM
AlaskaPowerStroke
Frozen REAR doors. :-)
Old Feb 2, 2005 | 05:24 PM
jetact's Avatar
jetact
Thats why I put remote start on my new truck and have the climate control on. It is always toasty warm.
Old Feb 2, 2005 | 05:34 PM
SoCalDesertRider's Avatar
SoCalDesertRider
What about throwing a tarp over the truck after you park it? Wouldn't that cut down on condensation inside the door jambs so there isn't a source of water to freeze the doors shut?
